MF 37 hay rake
Bradp
New User
How do you take it out of gear for transport or do you have to take the chains of we just got the rake and don"t know much about it.
Hi Brad, There is a drive clutch inside frame on
left side.To disengage the drive,depress the lock
pin by the outer perimeter and rotate the steel
band rearward approx 2 in. until the pin locks the band in this position. To engage, depress the
pin and rotate the band forward. These rakes had
one wheel drive or two wheel drive but this
procedure is the same. I have an orig.man w/light
use, reasonable. Chuck
Brad,
When i transported my mf 37 on the road for any distance at road speed i took the chains off.
Of course most of the time it was on the farm so we just unlock the drive as mentioned in the other reply.
37 was a good rake.
