LRRifleman
Hello!
Today I used my "new to me" 1970 Massey Ferguson Model 135 Deluxe for some field work, to see how it functioned. Needless to say, I was not overly impressed! I think with some work, I may be able to be satisfied with its performance.
My first use observations:
1) In pulling a Ford 2-14 plow, most cuts had to be made in first gear low. Sometimes, I could get away with making cuts in second low.
2) Generally, while using the plow, it took directional control from the front wheels if I used a "left bottom" depth of 6-8".
3) Apparently, a previous owner that "restored" my tractor crossed controls. In oder to control the tractor's speed, I had to use the choke. While I can't be certain, it seemed as though the throttle lever was literally "choking" the engine.
4) Toward the end of my field work, my tractor developed a "knocking" sound. This "knocking" disappeared whenever I depressed the clutch pedal, and returned when I took my foot off of the clutch pedal. Might anyone have a suggestion on what this problem is, and whether this is a major problem?
Thank you!
Thank you!
