2805/2745 injection pump swap
JCco
New User
I recently bought a later model 2745 tractor for parts and it has the simms/CAV inline replacement injection pump on it. I"d like to swap it onto my 2805 but don"t know if it will fit or if the injection lines will work. Does anyone know where to look up the parts list for the conversion kit? I my parts book only shows the rotary pump and the bosch pump, same with AGCO parts books online.
Hi JCCO,
According to my parts listings on this model, the injector pipes, timing case, drive gears, etc are not interchangeable between the two engines. The change came in at Serial no. XCU 527681G. Came across this same dilemma in an M.F. 305 cane harvester, many years ago,
hope this helps answer your query,
Evan.
The change over kit is no longer available, but I would think the pumps would interchange. assuming the 2805 now has the rotary pump.One of the things that I know, is that the intake "Y" at the back of the engine would need to be changed to one that is flat on one corner to except the space of the longer in line pump. Perhaps the two front and two back lines would need to be change .Would be worth looking into,I beleive
(quoted from post at 19:57:32 03/14/11) The change over kit is no longer available, but I would think the pumps would interchange. assuming the 2805 now has the rotary pump.One of the things that I know, is that the intake "Y" at the back of the engine would need to be changed to one that is flat on one corner to except the space of the longer in line pump. Perhaps the two front and two back lines would need to be change .Would be worth looking into,I beleive
Thanks for the info fellas. I've done some measuring and I'm not sure the pump will fit without the Turbo being in the way. I'm also not sure the injection lines will clear the different intake runners. The 540 sure runs nice wig that inline pump though.
