I just fully rebuilt my perkins ad3.152, had the head and valves done, new pistons, rings, liners, bearing, crank turned, etc.
I've been getting a loss of power and tons of black smoke. I pulled the air cleaner hose off to see if there was an air restriction and there was no change in symptoms...no rats nests or rags in the intake manifold either.
I was sure to put the inj. pump back on with how it came off, timing lines lined up.
My educated guess is the injectors or injection pump is not working correctly
After speaking with a few injector pump rebuild shops (both local and out of state) I can either:
1. Send both my pump and 3 injectors out of state and have them all redone totally (head and rotor reconditioned, injectors reconditioned (tested first of course)) this would be $695 for the pump rebuild and $100 for each injector so $1K total...but hopefully everything would be good.
2. First have the injectors tested and reconditioned locally to see if they are opening properly...this test runs $6 per injector. If they need reconditioning it would $40-50 each not including if I need to replace the nozzles which I think are about $35 a piece. For the pump, I can buy a new pump from Walt's for $681 new, and keep my old one...maybe sell it on ebay as a core...Walt's said cores go for $300 assembled, or $150 if I've dissembled it for any reason and couldn't put it back right.
3. Or have the pump rebuilt locally for $400-500 (not including the head and rotor). If I need the rotor and head redone the pump rebuild could cost $1,100 max.
I'm leaning towards first pulling the injectors and having them tested locally for $6 each. Then if they need reconditioning, having that done hoping I don't need new nozzles, so that would be around $150 and see if that fixes my black smoke.
If I need to have the pump rebuilt or replaced, the question is in the quality of the new pump, or should I just send it out of state for $695 and have mine rebuilt totally with head and rotor reconditioned.
What would you do?
What would you do?
