Hello!
I have a standard MF135 from around 1966. It has the hydraulics for the three point linkage which are all working well, but I only ever use them for occasionally lifting and moving the odd piece of equipment.
I'd like to buy and use a post rammer, the hydraulics of which nearly all consist of a single ram with single feed pipe. Therefore the hydraulic control requires that I can pressurise the ram to lift a weight, and then release all pressure as quickly as possible.
Is this possible of the existing hydraulic controls, or do I need a spool valve - e.g.
http://cgi.ebay.co.uk/MF-1457052M94-LASER-2-SPOOL-VALVE-BLOCK-/150477995480?pt=UK_CarsParts_Vehicles_CommercialVehicleParts_SM&hash=item23092ffdd8
As I said before, I only use the rear linkage for lifting, which is the outside lever on the standard hydraulic controls. I've never used the inside lever.
I think what's confused me is that I have another 135 that has a front loader. That seems to be tapped off a lug on the gearbox and is controlled from the standard hydraulic levers, so I'm not really sure how it all works.
I do lots of car mechanics and am competent mechanically, but tractors aren't my thing.
Thanks!
Thanks!
