Is there supposed to be some sort of rubber or fiber grommet that fits inside the fuel connections before you attach the lines? This is for a 205 industrial.
I replaced the fuel pump and the lines are leaking at the fitting for the inlet and outlet.
On my primary filter, I have some sort of fiber thing that goes into the hole, then the line and fitting butts up to this fiber deal and maybe that seals the thing...
Or is sealing supposed to occur from a brass compression thing that goes on the line and the fitting smashes it into the hole taper?
Anyone know? Thanks.
