'52 Ferguson
Don
05-28-2001 19:27:56
I have a '52 Harry Ferguson, serial #100368. When I am bush hogging, and into some thicker grass or even on a slight grade, the tractor, instead of bearing down, coughs and starts to peter out. My guess is I have something wrong with the carb or fuel mixture. On the carb is what appears to be an idler thumb screw. Is there also a fuel mixture adjustment screw, or something I need to adjust when it comes under load. The tractor idles just fine. To my knowledge, the carb is original. I have had the tracotr for five years and this is the first year I have had this kind of problem. Any help is appreciated.
Don
ashley haager
04-09-2002 20:15:58
 Re: '52 Ferguson in reply to Don , 05-28-2001 19:27:56
hellow my name is ashley haager i live on a farm near dolby. i am 13 years old i really like massey tractors. i am looking for a massy tractor for about $500.
Donny Hyde
12-28-2001 05:09:36
Have you tried changing plugs? Or fuel filter?
Ray,IN
05-29-2001 20:24:50
I happened on your post here, I usually am on The H.Ferguson forum board. I think the answers for your tractor are: The thumbscrew adjustment you spoke of is actually the power adjustment. Adjust this to 1 1/4 turn open, then fine adjust 1/16 turn at a time while under load. The tractor should run slightly rich, as the fuel provides some cooling for the valves by design. Under no circumstance operate at 1 turn or less, this will destine you for a valve job in the near future. The idle adjustment has a screwdriver slot in it, and should be adjusted after reaching operating temperature. I recommend using a carb., gas line cleaner mixed proportionally for the 10gal. tank, too much is not better! Consider buying a owners manual from a MF dealer, it's thin and packed with info. That's my thoughts, Ray,IN
