I have not changed the trans/diff/lift oil in my 202 yet since acquiring it a couple months ago. It is milky from water intrusion, thought it might burn off but after 3 solid hours of work last night the oil was barely warm to the touch.
The manual says non EP lube, but the stuff that is in there smells like sulfur and I suspect someone put EP in it. The lift arms, which are attached to a box scraper, drop in about 10 seconds if the pump isn't turning (clutch depressed). This I can live with, chaining it up since I'm just using the front loader at present.
I have 8 new gallons of GL5 90w I could put in it, but of course I don't want to do any more damage than may have been done. Should I ditch the GL5 and buy 8 gallons of non EP?
Paul
Paul
