Doing a rebuild on an ad3.152, and in fixing a thrust washer issue where they were too tight, I decided to take the rods off the crank so I could figure out how the crank turned without the pistons attached. In doing so, I pushed the rods with pistons out and one of my liners pushed out.
I think the liner is OK, it just fits in sort of loose. When everything was dry, this liner would not fall all the way in under it's own weight, but maybe 65% in, then would stop. After lubricated, and with piston and new rings, obviously it is loose enough to push out.
Should I order an OEM liner (other was A&I) that will most likely fit tight? Or should I just put it back in and put some loctite recess holder stuff on it to get it to stay...this may be easier and cheaper and save me having to hone new OEM liners. I've already finish honed all the liners, if I get new ones, I'll have to remove the crank again, and I'm trying to save my tab washers.
What do you think?
What do you think?
