Hi, so I have my 202 starting and running fairly well, front loader working fine. In the back I have a drag box with rippers. Been reading the ops manual and have a basic understanding of how the draft and hydralever work, and they do rotate the two upper link arms, not all that much but I can raise the drag box off the ground. However, if I have this right, the two levers just ahead of the seat, the Double Spool Valves I think, control the two cylinders on the drag box. I'm not getting anything when I move them, am I doing something wrong? Also, I need to move those upper link arms enough to clear the ROPS mounts so I can replace a broken clevis pin, they are not moving near far enough up to do that now, perhaps I have to unbolt the offending arm from the tractor?
Oh, and I have a blown exhaust gasket. Is it much more complicated than getting the 8 rusty nuts off and sliding the plot out enough to get a new gasket in place? Gas motor, 1959.
Thanks, Paul
Thanks, Paul
