I have posted about my 202 Industrial 3pt hydraulic pump and how it broke. It is essentially the same as a 35 from what I gather and I know you have answered similar questions previously.
Mine was making a banging noise when I released the clutch so I took it apart and found the pump in about a million pieces. In looking for a replacement I see there are ones with and without a strainer. Mine is without. Does it matter which I replace it with? I'm guessing a strainer is a good thing to have and may have helped mine not explode.
I am also wondering if it would be ok to run the tractor without the pump in place as I do not ever use the 3pt. because there is a backhoe which is driven from the front pump. I don't have any 3pt implements as of yet but I can always replace the pump at a later time.
