I'd like to replace my hydraulic lift pump filter and was hoping to find a paper element type instead of a metal screen type. Aren't there any available that are paper type?
This filter goes in a housing mounted to the side of my loader frame. I have a MF 205 industrial with a 200 series loader. The frame holds hydraulic fluid and is run by a pump mounted to the front of the tractor run by a shaft bolted to the crank pully.
Anyone know? Or am I just supposed to change out the old oil with new every so often? If so, how often? Thanks, I'm hoping there is a better solution than changing out all that fluid every time cuz that can get expensive.
