I need to replace the fan belt in my MF ? industrial tractor with a #200 loader and a #54/s backhoe. It has a front mounted hydraulic pump which seems to make removing/installing the fan belt a major job. Is there a simple solution to my dilemma? The belt seems to be "trapped" by the shaft that must run from the front of the engine to the pump in front of the radiator.
I also need help in finding the model of this tractor as none of the local "experts" seem to know. Here is some information: SN 9A 72490, Perkins AD3 152 engine, manual 3 speed /w high/low and manual forward/reverse shuttle, hand and foot accelerator, 3 point hitch, and the loader and hoe listed above. Thanks for any help.
pjroper.
pjroper.
