165 water pump seal
davemk
Does anyone know the part number for the seal in this water pump. the casting number is 37711260. I have the correct bearings but can not find the seal.
Dave
I have found the sparex part number S.40075 this is the rear seal. Now I just have to find a Sparex dealer.
Dave
I would replace the complete water pump.
Try Wenger for parts.
My orginal pump on MF65 lasted about 6000hrs.
If you replace seal, you should also replace bearing.
(quoted from post at 08:18:24 02/25/10) I would replace the complete water pump.
I am replacing the bearings. they are easy to find at any auto parts store. The number on the bearing is 6302z. the z means that one side of the bearing is not sealed.
Dave
