Hi, my 135 stopped charging around 18 months ago so i fitted a new dynamo and regulator and all seemed fine, about 10 hours work later and the dynamo failed, we thought it was a dynamo fault so fitted another and all seemed ok, then about 5 hours work later the new dynamo failed so we put it down to a dodgy regulator, fitted another new dynamo and a new regulator and all seemed fine, i have had the tractor in pieces for a few months doing a few oil leaks etc, when i started the tractor today for the first time after the work had been done it wasn't charging so i tested dynamo with multimeter and was only putting out 0.5 of a volt at half revs, quickly took dynamo to pieces for a look and everything seemed intact but i noticed there was no magnetism on the stator (should there be?), and it smelt burnt. i have fitted a new wiring harness recently and always polarized the new dynamos on the small connector, i can't think of anyting i could of done to make it eat dynamos, i recently got the fuel gauge working again but that was just that the float had gone past the stop and couldn't get back (easy fix), i also noticed that someone has added a earth wire that goes from the neg terminal and bolts to the dash, is this neccesery?, the tractor has all headlight harnesses and indicator wires removed, it has no wiper or anything only the essential fuel gauge and ammeter. any ideas why it has a fetish for dynamos?. Steve.
