Ok so now i get the tractor finally back together, after replacing clutch, tightening up rear end, replacing oil pan gasket, adjusting valves, and totally redoing all the wiring along with looming it all. I put 5 gals of diesel in the transmission (to clean out the water and gunk) and she fires right up. So i let her idle for a min and take off to the compressor to fill up the front tires they are about flat. I drive around and it still does not feel like the multipower is working. I stop back at the garage, and shut her off. I see hydraulic fluid/diesel pouring out the flywheel housing. So I guess i'm back off to split her again................. I'm kinda hoping that for some reason its one of the hydraulic lines that runs through the top of the flywheel housing, but i really doubt it. Is there a way to shut off the aux pump from pumping, maybe that will help narrow it down.
