Hello
I have a MF 550 combine that is having hydraulic problems. It does not want to raise the header when it gets hot. It works fine for the first 30 to 45 mins. of running in the field. Although it does leak really slow down during the first rounds of a field but you can still bump the button up and it comes up. After about 45 mins it leaks down and when you go to raise it up, it will not.
Has anyone ever came across this problem before, anyone work on these and knows what is causing this :?: We nearly know it is not the pump because the hydraulics would not work at all and they do except for raising the header after it warms up but it will probably be the next step. We've replaced both magnetic cylinoids and in line filter.
Any help would be greatly appreciated :!:
Thanks in advance for the Replys
~[b:8db6e77baa]TXFarmer[/b:8db6e77baa]~
