My neighbor has a 204 workbull that has some 3 point issues. First the draft control lever is stuck, the 3 pt hitch will only go up with a huge amount of weight on it, box blade goes up about 5 inches. I changed the hydraulic/trans oil and cleaned out the metal filter on the side of the engine. I have been debating on weather or not to rebuild that cover assembly under the seat. This tractor sat for 10+ years untouched in a grainery and has been running for 3 years now. Also, is there anything you can do about the PTO running backwards when you go backwards? He had a rude awakening one day with a brush cutter. Is it true that this tractor has a lot in common with a MF50?
