jasonelkins
New User
I'm looking for a good crankshaft for my TO35. Machineable is ok too. I just rebuilt the lower end of my Z134 Con't. I had the crank turned 0.060 over because it spun 2 rod bearings. New pistons, sleeves, rod bearings, main bearings. etc... Apparently my oil pump went bad. That is why i had to rebuild it in the first place.... I thought I just spun 2 rod bearings due to using synthetic oil. Anyway after running the motor for about 10 minutes it seized up. I simply can not afford a new crank. Anyone know where I can get a good used one? You can e-mail me at [email protected] Thank You!
