Averie
I recently purchased a Tru-scale hay elevator the rubber belt is broken, can this be replaced if so where would you purchase one or is there any repair shops out there that could do this for me?? just would like it to work like original. what would the cost be?? any help appreciated.
I have replaced the belts on JD elevators. The replacement belt is cut so you can feed it around the rollers. Then you have to sew the two ends together.
