Did they make a die cast of this particular tractor?
tazdale
New User
I have a friend that is looking for a die cast of this particular Case 970 Agri-King tractor. My friend has one that is this tractor but it has a dual wheel on one side for plowing. My friend wants one that was made with single wheels on both sides. I have searched all over the internet and can't find one. Has anyone ever made one like that? I don't want to waste more time looking if one was never made. I have attached a picture so you know what tractor I am looking for. Thanks for any information you can provide.
There is a 970 with cab that came out 1998.
There is also a Black knight edition that came out in 2002.
No 970 without cab was produced that I know of.
There is a 1270 without cab that you maybe get a decal set made for and change the decals.
(quoted from post at 00:06:51 11/10/18) There is an open station 970 Case with plow by Ertl right now on Ebay
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto2133.jpg">
I've seen this one, it has a dual wheel on the one side. My friend already has this particular one. Thank you though!!
That 970 must have come out in the last few years. I knew nothing about it nor did my guide from a few years back.
Ertl made a 1070 open station about 1998? It is the same casting
as the 970. Just change the decal and you have a 970.
There have been several versions made of the 9-1070 open station toy tractor since 1970. Ihis is a pic of the first Ertl 1070. Google CASE Toy Tractors and you will find several toy dealers on line.If you want to make an exact replica of his tractor, google Dakota Toys and you can order dual wheels and tires, plus 970 decals, and other accessories such as 3pt.
The last 2 pics are of a custom 930 toy which I built a proper front axle, cab, and swinging drawbar with 3pt., and the last pic is of real one that the toy was modeled after. I plan on building a replica plow for the toy this winter.
The 1270 is a wide body toy. There are a number of narrow body versions out there that would make a better replica. I never saw that 970 with plow either. I may have to order that.
Loren
If you are referring to the 16th scale 930 The duals were a kit with J bolts from Dakota Toys. I custom built the cab from brass sheet stock, and the front axle was also constructed from brass tubing and RC car parts. The 3pt was a combination of scratch built parts and pieces from Dakota Toys.
Loren
You have a lot of skill building stuff that?s for sure. I?d like to get a set of those duals to put on a 3020
