Dakota toys
SVcummins
Has anybody used the 3 point hitch from Dakota toys ?
The replacement steel 3pt hitch for the 3010 looks pretty much like the original. The cast aluminum hitch requires a lot of filing and cleaning. The holes have to be drilled in the aluminum hitch.
You will have to drill the holes in the cast hitch. It takes time and patience. Not a lot of room. The holes in the upper arms have to be drilled as close the the edge as possible with a bit that is .60 or smaller.
You might want to look through Dakotah Toys misc pages for a take off hitch. They have several plastic ones.
