504BalerGuy
I finish the 5020 that I asked questions about earlier. Thanks to all that posted and helped out. I used the directions from Mitchissippi that he gave much earlier about which primers and sanding.
I also tried filling the casting halves with spot putty. This worked OK, I think it will get better the more I work with it.
I removed just enough of the front axle to slide the rim off with it warm. However the front wheels were looser that I liked, so I add the axle caps.
The rear tires and rims are new, along with the muffler and seat. The front tires and rims are original. I used Armor All wipes on all tires and like the results. All the parts are from Dakota toys.
James
James
