Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tractor Memorabilia Discussion Forum
Re: Eska farmall pedal tractor help
Mmoline03
03-15-2013 09:38:43
I am doing this exact same project and having the same problem. I just separated it as far as I could and stripped it. I am going to use an angle grinder with a brush head to clean the crank and axle.
toddheck
03-16-2013 16:13:35
 Re: Eska farmall pedal tractor help in reply to Mmoline03, 03-15-2013 09:38:43
I have a problem also. I was training to remove the steering wheel and the set screw broke off. Any idea on removing it.
mmoline03
03-18-2013 12:10:47
 Re: Eska farmall pedal tractor help in reply to toddheck, 03-16-2013 16:13:35
Unless you can use a screw extractor and take the set screw off, otherwise you could cut the steering wheel off and buy a new one.
old fashioned farmer
03-16-2013 05:26:32
Howdy,
I have thought about doing that too. I also noticed the sprocket on the rear axle is just tacked on. I thought about grinding the weld off and just sliding the axle out of the sprocket, then re-welding it when assembling. Thanks for the idea.
--old fashioned farmer
