Tractor Memorabilia Discussion Forum
bulk oil storage used before bottled oil
Larry 2810c
01-31-2007 14:30:29
I have an old oil bulk storage tank with a hand pump mounted on top that was used by gas stations and repair shops before bottled oil. The unit has a serial number and the pump has a lever that you slide against the pump that premeasures the amount of oil to be drawn from the tank. The lever measures 1 pint: 1/2 quart; 1 Quart. I also have the original oil can used for collecting the drawn oil. It also has a long metal strip with oil volume marking that you pull up out of the tank to determine the amount of oil in the tank. Does anyone have any idea what this is worth. It is in good shape without and dents or scratches..thanks larry
Davis In SC
01-31-2007 15:12:16
 Re: bulk oil storage used before bottled oil in reply to Larry 2810c, 01-31-2007 14:30:29
I think the proper name for those is a "Lubester" I bought one several years ago, I need to get busy and clean it up. Those are actually a hot collector's item, among the car and gas collectors. They bring a big price, once they are painted and an oil co. sticker is applied. From my observations, the smaller lubesters are worth more than the larger ones.
To a collector, I would guess somewhere in the 150 to 200 dollar range for an unrestored one.
