212 electric lift
chris
12-14-2003 21:01:58
I HAVE A 212 WHICH KEEPS BLOWING THE FUSIBLE LINK
FOR THE LIFT MOTOR. IT SOUNDS LIKE ONE OF THE RELAYS IS STAYING ENGAGED. THE MICRO SWITCHES ARE NEW . ANY IDEAS WOULD A GREAT HELP
F-I-T
12-15-2003 04:22:34
 Re: 212 electric lift in reply to chris, 12-14-2003 21:01:58
Chris:
I had electric lift on my 214, and I did have to remove the motor and jackscrew one time and re-lube the jackscrew as it was dragging. I also had to replace the motor once when it dropped a brush. The motor is the same as an older GM window lift motor and it's a sealed unit. The two relays, which are automotive type solenoids, would be cheap to replace if you think one is hanging up. take one along and buy a common one at the parts store if you don't want to buy at the Deere dealer. I'd check the motor/jackscrew for excessive current draw.
Frank
