Went out to bush-hog yesterday. Raised rockshaft, then it would not go down. Control lever feels sloppy like linkage is disconnected. I'm sure I'll have to get in rockshaft housing. I have a service manual, the first thing it says to do is lower rockshaft. Anyone know how that might be accomplished? Is there a line or plug I can remove to bleed off pressure to allow rockshaft to drop. After it sits for a wile it does lower slightly, but as soon as I crank it up it returns to the full up position. Is there a way to access the valve from outside the rockshaft housing? Thanks for the help
