Glen D Anderson
Good morning,
Planning on addressing some leaks on the hyd. pump on our 4020(_______-200,999) and I was hoping someone could shed some light on the sealing system for the caps that retain the pistons / springs.
Working on pumps from our other tractors in the past I recall being provided with a teflon sealing washer in addition to the o-ring for the cap as part of some update. As I recall, the teflon washer was to be installed between the o-ring & the pump. Looking back on that I can't see how that would even work. My thoughts is that the washer could deform / pile up during installation preventing the o-ring from sealing at all?
I've attached pictures of the pump in question showing one of the caps that obviously has the teflon washer installed. Ironically, it happens to be one of the 2 that's leaking......
Long story short, what's the best fix for re-sealing these caps?
TIA
TIA
