On my Aussie 2140 2wd which is about the equivalent to north American 2750 utility tractor, I think that somewhere within the hydraulic system or the mechanical workings I have maybe broken, bent or damaged something.
What happened? I was brush hogging and went down a small embankment, about 3 ft high, but was a little steeper than I reckoned. At the bottom I went to raise the 3Pl and it would not lift. The arms moved a little but would not lift and load.
I disconnected the brush hog and the following would or wouldn't happen.
The steering was a little jerky when going from lock to lock.
I could not select high range on the 8 sp transmission.
The handbrake seemed to be at least partially locked on.
When I raised the lift arms by hand, they now appear to be locked in the raised position and I can't get them to lower, even with the engine turned off.
There seems to be a slight clattering noise somewhere from within the transmission.
Any thoughts or ideas as to what my problem might be. The pump has been checked and new seals etc fitted.
