John Deere 143 Loader
Phil in MS
12-03-2003 14:46:46
Anyone have any idea what size of tractor a JD 143 loader would fit? I'm not sure I have ever seen one with these numbers.
Dale in IN
12-04-2003 07:20:44
 Re: John Deere 143 Loader in reply to Phil in MS, 12-03-2003 14:46:46
Phil:
I have a 143 loader on an 830 (3 cyl) utility. This loader fits the smaller utilities like Mike says. I bought mine new in 1977 with the 60" bucket and bolt in tangs. It is a nice little loader. The only problem I have had with it is bending the tangs when I try to do something that they were not intended to do. But I just take them off and straighten them. The bucket only has 1 cyl in the center for hyd dump. This cyl seems to be the weak point. I have bent the cyl shaft several time and straightened it and got it to work. I finally replaced it with 2 2" cylinders with larger shafts and have had no problem with them whatsoever. The 2 cyl.s require a little more oil than the 1 Cyl and this causes the bucket to dump a little slower.
My loader says made in Canada.
MIKE HANLEY
12-03-2003 20:41:13
The 143 is NOT listed in the 1975 sales lit. It shows up for the first time in the 1976 sales lit. Tractors listed for it's use:
820, 830 (3cyl) 1020,1520, 2020, 2030, 2040, 2240, and 2640. (920, 1030, 1120, 1630, 1830, and 2130 in Canada) Specs as mounted on a 2240 tractor: 9'5" lift 1600# full lift 2450# brakaway Digging depth 6 1/2" Lift cylinders 2" Bucket cylindes 2 1/2" Weigth of loader 832# Attachments: 48", 60" or 72" materials bucket. Tines for 60 or 72" manure bucket. Extentions for 60" bucket. Bucket level indicator. Mounting stands. It was the economy loader of the line at the time.
Bob Richardson
06-25-2004 08:40:19
 Re: Re: John Deere 143 Loader in reply to MIKE HANLEY, 12-03-2003 20:41:13
Does any one know where to get a operatores manual for the 143 loader? If so could some one let me know.
