Early 4020 flywheel
S.C.
New User
Just got the clutch assembly and flywheel off. Flywheel doesn?t look bad and not much wear. If I have the flywheel ground what is the depth measurement? Is 2.844? correct? Do the dowel pins have to have the steps cut down so the backplate will seat on the flywheel? I wonder if I could get away with just replacing the disks, springs, and anything else that is broke or worn. Thanks for any advise.
