jd 720 rear tire width
(reply to post at 15:31:58 09/11/18)
will try to make this a little easier, a standard 38 in wheel-tire can the width be set out side to outside less than 82in?
thanks (needs to fit on my 84in wide trailer.)
The overall width is the track width plus the tire width. Almost all tractors (your 720 included)
can be adjusted down to a 60" track width so assuming you have tires around 16" wide the overall
width would be as low as about 76".
