Tractor Identification
herk
Hello Bought a Industrial tractor (gas) with a loader I don't know if it is a 2010 ( no serial no on block ) or a 400 ( no serial no by the brakes peddles ) where else can I look? it has the forward and revers H L N R shiftier on the left, gear selector on the right ? how do I ID the loader I believe it is a 400 or 720 ?? Thanks Bryan
Serial plate on JD 400 will be on RH top side of trans case under seat. Sounds as if it's possibly a model 500 if it has shifters on both side of steering wheel. Can you post a photo?
I lived in Mankato MN about 58 years ago. Cannot say I remember much but I have been there. Still have family up in MN not far from there
Hello the guy I bought it from thought that it was a 1010 when he wrote the ad but when i
talked to him about it he thought 2010 I wish I could post more pictures of it . Thanks
Bryan
If I had your Email I could forward you a pic of the dash he removed the cab . Thanks
Bryan
My knowledge of JD industrial tractors is very limited due to the fact that I was employed by an "Ag only" dealer. Your tractor isn't a model 500 as I suspected. I don't know what model it is but maybe some other member does. Here's the photo you emailed me.
Sorry I can't help you with the model. I have a '71 400 tlb and it doesn't look anything like that. My 400 has the shifter between my legs with a left hand reverser. Mine has the joystick for the loaderand yellow color. Those are the only similarities.
Wont find the reverser in the AG parts manual. You must look in the forklift, wheeled landscape, etc.....
Item #38 below is the power reverser. My JD2010 Industrial Service Manual, shows a lot better picture.
[/img]
Thanks for all the info, last night after milking I found where there had been a tag riveted to the block , I sanded paint off an found no stamped into the cast 23111 , my guess is it is a 1962 2010?? Thanks Bryan
