hey guys i am having an issue with my 48 b model. after mowing my front field it ran great maybe a little low on power but this was my first time using it for work. it has never idled right since i have had it. it was a non runner at first. had a rebuilt mag from Rudy Calin i did the carb myself but did not do the idle passages at this time. it loped i did lots of reading and it was pulling from the load so i ordered the bits and gaskets and went thru it again. i thought I did a good job this time but now it won’t even run. i tore it apart and re cleaned several times i swear it gets worse each time.
fresh gas from the pumps this week. compression is 110 both sided tried new plugs it has good spark and the same as my d model that runs good. for good measure i tried new points and condenser to rule things out. i had to mess something up readjusted the float level to level with bowl. 38 space 12 space from float to bowl. recheck nozzle and passages. removed oil bath lid no change
any ideas are appreciated. i have done lots of googling but am going cross eyed
