Discontinued PTO part R69511 part needed
So far I have been unable to locate a R69511 "bushing" that is part of the pto thrust improver kit for a 2640 Deere. It may have been "standard" equipment on the industrial versions of those 2xxx tractors. Mother Deere discontinued the part and I've had no luck finding a used one. Anyone know of such an animal or have one that can be measured so I can have one made?
They don't. John Deere still lists it too but they don't have it. I have ordered two from those Google results that was cancelled by folks when they found out Deere doesn't have it. All states was able to find one so assuming that doesn't fall through should be ok now.
This is the disclaimer I see when I enter the part number in my JD shopping cart.
The part R69511 is no longer available. Contact your local John Deere dealer for other options.
Have you tried to get bushing at a tractor salvage yard?
When you get it, maybe post the dimensions so that anybody else looking for one can make one. Heck might even be beneficial to you in the future should you need another one.
Yes, I plan to measure it and make a drawing. Most could be figured pretty easy measuring housing and bearing race but depth of race and depth of OD in outside flange would be more exciting to figure out. I'll try to dig this post up and include dimensions so I can search for them one day :)
