cheny59
New User
I have a 3020 gas tractor, SN134429, 241cid, crankcase number R40690. Looking for Standard 3 ring piston, rings, and sleeves kit. Overhaul gasket set. Standard rod bearings. My serial #seems to be high and cant find part numbers to order to get it back together. Connecting rod has a JD number R44257. 4.250 bore.
according to JD they don't have a gasket set for this engine anymore. Does anyone know any part numbers or someone that I can get these parts from. Thank You.
I recently priced a Reliance out of frame kit for a 241 gas and it's right around $3000. It includes just the pistons, sleeves, rod and main bearings, gasket set, and maybe head bolts. So beware that these engines can get expensive fast.
I have never found anyone that can beat the price of Reliance Engine parts that RF Engines offers. link below:
https://dieselcranks.com/
With out any part numbers for the 241 engine, All state ag parts and Yesterday Tractors can not come up with in frame overhaul kits. most of there kits are around a 1000. Thanks for the help. will check out add posted below.
