Late model 4020 wide front needed
df
I am looking for a OEM wide front for a late model 4020 with the 2 bolts on the main frame of the wide front (JD part # AR50865) instead of the 4 bold version for the earlier model 4020's.
Don't know if this will help you because its not OEM but A & I products in Rock Valley IA has new reproductions. I put one on my 72 3020 and cannot tell the difference from the OEM. Their number 800-657-4343
I would put a conversion from a 4430 before putting factory WF on, the original was undersized.
Look closer you can tell the difference.
The A&I is heavier. (center casting}
If you go with the A&I replacement front end, I beleive you need to get one thru your local A&I rep or dealer. I dont think you can buy one directly thru A&I in Rock Valley. At least I seem to recall that when I purchased my A&I front end.
