Power trol info
ET
I'm 150 miles from the operators manual for my late A. I'm having a problem retracting the jd hyd. stop cylinder. The power trol has two adjustments on it. What is the base line adjustment for running a remote cylinder? If I remember right the bottom screw on the back is rate of drop for the rockshaft.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">What is the base line adjustment for running a remote cylinder?[/i:654c4848f0][/b:654c4848f0]</font>"
Reviewed the [b:654c4848f0]OPERATOR'S MANUAL No. OM-R2002R JOHN DEERE MODEL "A" SERIES TRACTOR (SERIAL No. 648000 AND UP)[/b:654c4848f0] in the [b:654c4848f0]POWER LIFT AND POWR-TROL[/b:654c4848f0] section under the [b:654c4848f0]Adjustment of Powr-Trol Metering Screw When Remote Cylinder Is Used[/b:654c4848f0] topic on page 42.
Take a look at the information below.
a276142.jpg" width="650"
Take a look at the photo below of the metering screw.
a276143.jpg" width="650"
Hope this helps.
