(quoted from post at 18:36:53 08/03/18) Thanks for sharing that info.
After the complete LED conversion you'll have amperage to spare for more lights or other accessories. LOL
BTW, what year is your 4020 & what lights did you use for the rest of the conversion?
Glen, the 4020 is a 1968 model. I'm not quite done but close to finishing up, I could post then or now any info anybody would like.
I will attach a picture of the dash indicators I installed LED's in, I had ordered, amber, blue, and red bulbs, but blue was just to bright. Ended up moving amber to left side for electrical and using red for oil pressure.
The dash light I hope to work on tonight and get that back in and try out which light I will go with.
I ordered lights from Larson Lights in MN, and got the extra housings for the fender lights from Martin Parts in PA. I didn't want the housing with a hollow bolt, I wanted ones where the wiring leads connect to the bottom. This way dust won't get in there and I could use the factory wiring that was there.
Currently I have spot lights in the inside fenders, and on the left fender the outside light is a trapazoid and the outside light on the right fender is a flood. When I take it outside in the dark and aim then I want to see which I prefer.
Last year I did put a light bar on the front to replace the two halogen lights dad had installed, but while the hood was off (putting in new hood foam) I also wired in an automotive relay for the front light bar.
Oh and also LED A&I flashers for the ROPS. Then a fluted flood light (looks like the old orignal glass) for the rear light. Hopefully will work out well and Dad will be happy with it. Still use it for field work so wanted to convert it to LED's. And your right shouldn't draw near the power as before!
Ryan
