Hvilletractors
New User
Hi All. I have been looking around on the forums for a good while as I have chased a few issues with a model A this summer. I haven't really came across someone with exactly the same issue that I'm seeing and was hoping that you guys could give me some pointers. I apologise for what will be a rather long post.
The issue is, the tracor will idle fine at any throttle speed. Will run good under load while bush hogging or such. But, stumbles really hard when load is applied like starting off from stop and beginning to accelerate in a higher gear or if starting on a hill. It also seems to do it much worse when it is hot, sometimes to the point of not being able to get going. You will have to tease the clutch in and out just to keep it from stalling out until up to speed. But then it is fine. It will climb a steap hill in 6th gear with out any issues if already up to speed.
I recently went through the ignition changing the coil, condenser, rotor, and points and plugs. It is the Wico XB system. A friend did mention that the rotor cap was worn but have not got a new one yet. These parts were changed as result of suddon onset of the tractor running bad, cutting off, and not restarting.
Any ideas, thoughts, or suggestions are highly appreciated as I'm not exactly sure where to go from here and don't want to start just changing parts. Tractor show season is coming up and I'm wanting to get it back in good running shape
Thanks in advance for the help!
