I just replaced the front tires on my 4020LP. 6 Ply Bias,7.50x18's The rear are 18.4x34 bias ply.
I've looked around for correct tire pressures and there are so many onions as to what is correct I'm not sure what pressures to use.
My tractor has two additional weights on front and the rear tires have one weight. The tire are air filled only.
The tractor is used with a drag blade for road maintenance, drag a bush hog and a post hole digger.
Right now I have 25PSI in the front tires and 20 PSI in the rear. Would these pressures be correct for my use?
Also, How do you do a search on this site. It is not obvious to me?
