Dougin texas
Have a JD 535 baler-pressure on baler when starting a new bale the gate latch will not stay closed all the way unless I just hold a slight pressure on SCV, once bale get started the pressure gauge on baler baler will jump up to normal pressure and gate will then stay latched and can make bale.
This happens on every bale, pressure gauge is showing low until bale is started and gate latch starts to open, but as soon as I get a little hay into baler the pressure gauge jumps up and all is good
Could this be caused by one of the tension cylinders leaking internally
