4020 part I.D help Please
Rapidrob
I was cleaning the cab of my 4020 ( 1968) and noticed the seat just did not feel right when I sat down. I took the seat apart and found that two of the sliding bearings in the two seat tracks for distance to the pedals are missing. They appear to be made of a hard white plastic. They just slip on and are held in place by an axle pin and the bearing tracts. Can anyone here provide a part number for these plastic bearings? Who may have them? I need two for sure.
R26436 roller $2.66 $2.03 from A&I
R26872 shim 0.010" $1.01
R26873 shim 0.020" $1.33
Replace all four and you will need some shims as well to take all the side to side play out. If you go on Ebay there is a seller who has a complete kit with all the rollers,shims,bushings,metal rollers,cable and a new clock spring for around $100. I used one on a 2520 this spring and was pleased. Tom
