JD 530
Changing the power steering fluid did not correct my problem. The steering wheel still has to turn about 3/4 to 1 full turn from center before I get any movement from the front assembly. There seems to be only about 1/2" play with the steering arms and tie rods.
I just mow with this tractor and it had worked fine before, but with the last few mowings, the steering seems to be getting worse or almost non existent at times. I have a service manual, but that only says so much. Is this the flow control valve, even though the steering WAS working fine?
Also, I may add, that when driving, it seems the front wheels could go quickly in one direction, but then come right back, when going straight. It happens real quick though.
Thanks for the help,
Bob
Bob
