So Last night decided to get the 42 john Deere B out, so it can see the light of day once again.
Haven't moved it since last October, & needle & seat was sticking on then.. So Cleaned up the carb
inside & check the float reassembled & checked on the bench again seemed OK.. Reinstalled it &
connected up new 6V Battery, Figured I'd check for spark before cranking it & looked good, reinstalled
the plug & tightening up with my fingers must of leaned pushed or turned the flywheel wheel a tad but
it was enough to make the impulse snap. I think The shock off the end of the wire from my index finger
to the elbow on the opposite arm, HOLY FREAKEN COW... Yep Good spark, Popped right off...
