Brass gas line fittings
Dwashebek
Where do I find a good selection of brass gasoline line fittings? I want to retrofit a shutoff valve in line with the gas line or install it where the gas line fits to the three way valve on a 47 JD A tractor. Thank you.
Are you looking to match the original fittings with the "gland-style" ends soldered to the steel line, or two modern-style compression fittings to join the cut ends of your line to the new valve?
Other option would be "inverted flare" fittings if you can double-flare the steel line.
ANY "real" auto parts store (NAPA and the like) should have compression and inverted flare fittings in various sizes.
