Part # AT21721 shaft for 2520 distrubitor
pjgleason
New User
I have a 2520 and I am looking for this part and deere says it no longer available can anyone tell me where I might find it thanks
Part #AT21721 comes up as "KIT, SHAFT BEARINGS, WASHERS, AND SPACERS", which apparently doesn't include the shaft, which is listed separately as Part # AT21995.
What do you actually need, the bearing (bushings), the shaft, or both?
(quoted from post at 09:09:23 07/26/18) Part #AT21721 comes up as "KIT, SHAFT BEARINGS, WASHERS, AND SPACERS", which apparently doesn't include the shaft, which is listed separately as Part # AT21995.
Both if I can but could probably get by with the shat kit
(quoted from post at 09:42:35 07/26/18)
if I cant find them I will get the rebuilt unit
So you are saying you could perhaps get by with just the bushings?
I will look at an old catalog and see if I can find any Prestolite part numbers for those bushings, mite be some out there if one had that number.
Also, oilite bushing stock is readily available, and it would be a simple job to make up a couple in the lathe.
