Several years ago I replaced the 1.38 ci pump with the 2.4 ci pump on my 2630 FEL tractor, in the last year or so I have had trouble with the loader hydraulics losing function when the tractor is idled for more then a min or after it gets hot in either case you can regain hydraulic function by reving up the tractor and keeping it at a high rpm. While trying to diagnose I checked the valves for heat and found the pressure control valve got quite hot while the tractor was just parked in neutral and not using any hydraulic function and while looking at the valve in the tech and parts book I saw they use a different valve and a "stop" in the pressure control valve that was meant to be used with the 2.4 ci pump then what is used in the 1.38 ci pump. My question is do you need to "upgrade" the pressure control valve when the pump is upgraded and if this could be the cause of my problems? any and all thoughts are greatly appreciated.
Chris
Chris
