47 John Deere A charging system
sarahandmike
New User
my amp meter only stays in the negative side of meter(around 10.8v), at full throttle it just enters positive side of meter, I have always have wiring problem so I frond a diagram rewired the tractor wire by wire still no change.
Also,
Very Important that tractor is wired correctly for the type of regulator you are using, 3 terminal, 4 terminal, cutout relay, ect.
