I recently bought a 1966 4020 power shift with pencil injectors. the owner died app 8 years ago and the tractor has been setting in a shed since then. before he died he had the injector pump replaced and new injectors installed. they had the tractor running at the auction and it was leaking fuel at the rubber boots on top of the injectors on 3 cylinders. I ordered new boots even though the ones on the tractor looked new. the injectors still had anti sieze around the bottom them, so the tractor had not been run much. is there any thing I need to do to keep the new rubber boots from leaking when I install them? do I need to coat them with something besides oil, and would it be better off installing hose clamps around the boots instead of the spring clamps. I think the hose clamps would look cheezy. any help would be appreciated.
